Wall Mounted Grinder Rack Tools
A wall mounted rack for hanging your grinding tools.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Langmuir Systems for the original creation.
2690
  • GrinderHolder.dxf
  • Gregory Glumm - 5 years ago
    Thank You for sharing
  • Alex Meisner - 5 years ago
    How do you blend in the letters to the top, so it actually cuts around the letter rather than inside?
    Scott Gayden - 5 years ago
    Check out this tutorial on using the 'union' function inside Inkscape, Alex. https://www.youtube.com/watch?v=jxhR9aT6crU - Scott
  • jay nielson - 4 years ago
    What a great grinder rack. Can’t wait to put it to use.
  • Jim Douglas - 4 years ago
    Thanks for the design. Just FYI it wont fit a 4-1/2" grinder if the safety guard is attached. I going to modify it to allow that. If it works will post
  • James Perkins - 3 years ago
    File does not work...As soon as the Letters cuts....Stops
