I really like having my grinders easily accessible in my shop as I'm constantly cutting or grinding something with 'em. Inspired by some designs I saw online, I made a few slight modification to the Langmuir grinder rack to hold the wrench for my grinders as well as a variety of frequently used and consumed grinding wheels. I designed this so the top bends up instead of down, and it has 3 built-in hooks to hold my grinding wheels and one shorter hook to hold my grinder wrench. The hooks are bent out at a 45 degree angle. NOTE: As someone else noted in Langmuir design comments, the grinders do balance well, but do not fit/fall completely into the rack due to the width of the guard...at least that is the case for my harbor freight grinders. I thought about removing the guards so the fit better, then realized they fit fine as designed...and my hands may thank me later for leaving the guards in place... I used 22 gauge steel and it seems perfectly sturdy. This somewhere in the neighborhood of 19.5" x 12.5" when cut flat.
Wall Mounted Grinder Rack by Langmuir Systems
646
