This is a set of Splash Guards for the X gantry to help keep splashing water in the table when cutting near ends of X stroke as in cutting full sheets. I made these out of 16 ga SST. The small tab that is bent up was a little tricky to bend but dropped a few images on how i did it. The chamfer at the lower leading edges is important as it cams the guard up at extreme ends of the Y stroke. so the leading edge does not stop the gantry at ends of the water table see images. I may add another small wiper under the edge such that a rubber strip can lay on the top of the 1" water table side tube. I will post that mod if we do it and likely not drill any holes but use some rubber strip that has adhesive backing. Our water table seams are not flat with each other so something flexible to compensate for the differences at the seams. Alt I may run some 1"thin wall aluminum angle down each side glued in place so the wiper can run on a smooth flat surface. Ken
115
Water Table Splash Guards Xplormor Offroad @autotech AutotechKen XR Splash Guards
