Very cool, the integrated bend lines are a smart idea.
4WheelinManiac - 5 years ago
definitely going to use this!
Tom Johnson - 5 years ago
I will download the file when I can to try to understand how you put those bend line cuts in there. I haven't been successful cutting slots so that I can bend on. Not sure about the setting.
Robert Phillips - 5 years ago
for slots, try to put your lead in point at the meddle of the radius and set the angle to 90 degrees.
Beginner - 5 years ago
Hi, how are you bending the plate or which tool to use? thanks
Eric Wiersema (OP) - 4 years ago
I just put it in a 3 foot brake and bent it, you could try a bench vise also
