Hmm, I loaded the file but am getting a "bad character used, Block = 0" message. Also, what thickness material did you use?
thank you
Joseph OReilly - 5 years ago
Oops, forgot to run the dxf through fusion 360 first.
ShaunyShaun - 5 years ago
Gauge metal?
Jamie - 5 years ago
looks like 1/4 inch ish. the tabs are .273
Nick Koupiaris (OP) - 5 years ago
1/4”. Could easily edit the slots to accept 1/8”
Carl Swinford - 5 years ago
are you guys saving the project file or saving picture and converting it to dfx? I cannot get the project file to convert to anything other than zip or 72 and that will not load into fusion
Brian Ricklefs - 4 years ago
I'm all over this project!! I downloaded the DXF and I can get all the way to being able to cut it out HOWEVER.... Could someone who is better at this stuff than me place all the hooks in a nice tight pattern around the collar so it doesn't waste near as much metal when you cut it out????
Jamie - 5 years ago
