Attached is a DXF file. This is designed around .06 Thickness (16 Gauge). Two larger slots are for large C-clamp style Vise Grips with .5" slot. Third slot is for regular Vise Grips with .21875" slot. the other 4 slots are .25" and I have those for Combination squares. Four mounting Holes at 16". Other 1.5" holes, you can dimple die them in reverse. Whole setup is 19" wide, 2.5" tall. its 2" to bend and 1" bent at 10 degrees.
67
vise grip holder wall mount
