23.5in x 29.5in deer head wall art. If cutting on a Pro, remember to rotate 90 degrees. Yes, I know I spelled deer wrong in the file name. Settings are for 14ga MS, cause that's what I had. I cut with 37amps and it came out beautiful. The file has mounting hardware nested in the horns that needs to be bent at the cut lines and welded on. Stands 1/4in off the wall. Hooks were welded just above the horns in the center. Smaller standoffs were welded in the bottom left and right sides.
378
art deer
