I made this about 14 x 22. Any smaller and there is a good chance that you will wind up cutting things you don't want to. I use an Everlast 52i with fine cut consumables cutting 16g hotroll. Very important have your kerf programmed properly. I grabbed the images that make this design up from a variety of online free sources of dxf and svg. I assembled them, made the plasma cuttable and modified the artwork where I didn't like it. Included is the g code I used. I personally would suggest you take the svg and run it thru your gcode creating program...that way you can create gcode that works best for your setup.
135
dump truck
