This is the hanger that I will be using for the throttle pedal that I uploaded last week. This pedal set will be a hanging style, not a floor mount. I should probably point out that I am making this set out of 1/8th inch steel so it is heavy and will be hard to push. It would probably be a good idea to cut these out of a lighter material, which will absolutely require that you adjust some of the dimensions before you put this on your machine should you decide to use this design. I broke my back a couple of years ago and have subsequently lost a lot of feeling in my legs and feet, so I tend to push too hard and break pedal sets. This is why I am making these so heavy and they will need of a lot of pressure to make them work. Please keep this in mind before you go to your cutter to create these. Also - a lot of the hole sizes in these images are reference points that will need to be drilled to size for bearings and what not. Some of them are not final sizes.
22
Racing sim throttle pedal hanger
Jim Clark (OP) - 1 year ago
Mathew Rupp - 1 year ago
