After much experimenting, I settled on these designs to prevent splashing on the back and side rails of the Langmuir Pro. Before these, I was constantly having to clean the rails. These have eliminated nearly all splash to the rails. And it is a matter of one bend on the Back Splash Guard and two bends on the Side Rail Splash Guards after cutting them out. You simply set them in their place and easily remove them when needed. You'll obviously need to print two Side Rail Splash Guards and make opposing bends in each one. You may want to add a couple of additional subtle bends to the Side Rail Splash Guard to allow it to hug the rail better AND miss the bolts on the front of your machine. I did my bends to the side guards so they are barely still over the water tray so over splash drips back into the water tray. You will see from the photos that I also have a couple of tourch guards that have worked well. I used 20 guage steel for my guards.
64
Splash Guards Water Pro
