Modified House of Chop design. 1/8 for the base, 1/4 for the top. Top designed for my HF saw so will need to be modified for other saws but the base should work for any saw.
You may distribute, remix, tweak, and build upon this work, even commercially,
as long as you credit Bob Dobinson for the original creation.
Rough dimensions if I remember correctly - Top is 18x13, base is 14x11. If you load it up in Fusion 360 you can check the measurements
Mike Blake - 2 years ago
I put this together and it works pretty good, but Im curious as to how everyone attached the saw to the table? right now mine is just clamped on, would like to mount it better
Bob Dobinson (OP) - 2 years ago
I drilled/countersunk holes and mounted it to where the guide plate attaches. I did need a shim to get the correct thickness.
