If you have a 5.2 0r 5.9 Dodge Magnum engine that is older I'm sure you are familiar with the plenum gasket failure on the bottom of the intake manifold. I made a solid piece without the bolt holes because I TIG welded mine onto the bottom of the plenum. The holes are for someone who may want to make a thicker plate out of some thicker aluminum and bolt it on with a new gasket. It should measure 16.87in (16 7/8in) from the top left corner to the bottom right. Happy Cutting
69
