NEJE E40 Laser Adapter for Langmuir Systems Crossfire Pro Tools
NEJE E40 Laser Adapter for Langmuir Systems Crossfire Pro Located: https://www.printables.com/model/441486-neje-e40-laser-adapter-for-langmuir-systems-crossf
You may remix, tweak, and build upon this work non-commercially, and although your new works must also acknowledge trevieze and be non-commercial, you don’t have to license your derivative works on the same terms.
47
plasma CNC
  • quinn - 1 year ago
    what program runs the lazer
    trevieze (OP) - 1 year ago
    There is a Arduino UNO sketch on Printables that generates the PWM signal and turns on the air assist.
  • trevieze (OP) - 1 year ago
    There is a control box that interfaces with the crossfire pro. Instead of plugging the torch on cable into the plasma cutter, it gets plugged into the laser controller. The description has a link to the engineering to build a laser controller. https://www.printables.com/model/441486-neje-e40-laser-adapter-for-langmuir-systems-crossf
  • Robert - 1 year ago
    does this work on a standard crossfire?
    If you are comfortable with building your own Pulse Width Modulation Controller than yes this will work with just about anything. The Langmuir plasma controller provides a dry (isolated) contact to signal the plasma cutter to turn on. The PWM controller turns the laser on with a preset duty cycle the same way.
  • Ken - 1 year ago
    Thanks for posting this so suspect the XR controller could be adapted to this as well. Not sure how the fire control interface would interface it or is that disabled or faked out when running the laser. I would think you would run the g-code XY through fire control and just turn the laser on similar to start of a plasma cut
