Motor Guard M60 air cleaner mounting bracket. This is another take on a mount for the Motor Guard M60 mount with 1/2" NPT inlet/outlet. This has tabs to capture the 1/2 pipe securely. It is designed to work with McMaster-Carr 4" exhaust bracket part # 3042T23 or it can be mounted directly to a wall. Holes/slots are 3/8" and oversized to 0.3970. Bends assume this is cut from 0.125 (1/8") material. Also includes an optional locking plate that can be secured with #10 bolts to capture the 1/2" pipe. When cutting, make sure to cut the bend lines with no offset (or skip them if you want). Filter not included :) Happy Cutting! Leave a comment below if this helped you out! Enjoy!
415
Motor Guard Motorguard M60 Motorgard Filter bracket
