This is a remix of the original laptop stand by Wyatt Lassiter, made for the Crossfire PRO, so it bolts to the corner of the table instead of a leg since the PRO's gussets make the leg not usable. I added gussets and widened the piece attached to the bottom of the laptop holder part to stiffen it up since I was going to use thinner material, if you are using the 1/8" that was suggested, it may not be necessary. I also modified the main piece and added brackets to hold a three piece pipe hinge instead of the original purchased hinge because that's what I had. They're sized for 1.5" OD pipe but feel free to adjust for what you have.
Laptop Stand for Crossfire by Wyatt Lassiter
898
