This is a grill guard that is mounted to the factory bumper on a Kubota L2501 tractor. Always check the dimensions to make sure it will fit your tractor because i have been told they factory bumpers vary a little from tractor to tractor. You will need to design the orange circle to be cut out if you want to add it. I used stainless steel bolts to hold the circle to the grill. I also painted the grill with undercoating spray paint for the textured look. The mounting holes are 1/2 inch bt you can adjust to what ever size you want, also use stainless steel bolts to mount to the tractor.
31
Grill Guard Tractor Kubota L2501 Brush Guard
