Had a pin and bushings milled for this project that was the most expensive part at 400$. steel used for thumb was 1/2 in. razor weld cut it no problem, though there was about a 1/16 in deflection in the cut really maxed machine out. yes it looks like it is sticking out a lot but it is not retracted all the way as the lines were not hooked up when I took this picture.
140
Advanced
Hydraulic Thumb
