Double sided address sign for mailbox or post. I added the numbers into the design so all you have to do is copy, paste and move to the position. Make sure you place one set of the backwards numbers, so they show up correctly when you bend it. i used rivets to put all 3 panels together which holes are already positioned. The half moon ticks is the bend locations on 2 panels. the middle panel with feature doesn't get bent. I used 16ga. wand 3" reflective tape for numbers. Really simple to add whatever you like to top and change the design. If you have any questions, please just message me on the forum.
82
