when i opened this in fusion 360, it seems the individual lines are broken apart and can't be cut as a whole part.
Kyle Henke - 4 years ago
Same I just connected them all then you have to fine the broken line in the spine. Its in the left side middle.
Todd Kelch (OP) - 4 years ago
I think it is because the original file what's meant to be a puzzle so that you break out the pieces and build it. Basically built in tabs . Fusion 360 isn't friendly with cut lines.
.... Also you may have to adjust the slot size to your material thickness...
Rock Mountain Fabrication - 4 years ago
what thickness was the original file for? if using 1/1 sheetcam?
Todd Nadell - 4 years ago
Is this best made out of 1/8" material or could you use 1/4"?
Todd Kelch (OP) - 3 years ago
WHEN YOU OPEN IT IN SHEET CAM, THE CONNECTOR INSERTS PORTION WILL BE YOUR MATERIAL THICKNESS. REMOD TO MATCH YOUR MATERIAL THICKNESS.
Chris Allen - 4 years ago
My grandson will love it. Thanks
LYLE - 3 years ago
how big of a sheet does this use? keeps coming in either really big 160"x115" or like 5"x3". maybe im doing something wrong
Todd Kelch (OP) - 1 year ago
I havent been on in a while!!! Scale to suit your size and adjust the tab width to match your material.
Andy Carpenter - 2 years ago
Trying to visualize what a finished puzzle would look like. An assembled photo would sure be nice.
