I just got my Langmuir Crossfire XR setup and started to use it when I decided a laser alignment tool would speed me up when setting up my cuts. I looked around, but only found prints for the Crossfire Pro. After some thought here is what I came up with. For power I cut up an old USB cable and wired it to a switch I had laying around. I ran some 2 conductor wire up the track with the factory wires and connected it to the lasers with wago style connectors. I bought the lasers from Aliexpress. Originally I planed on using a set screw to hold the lasers in place, but ultimately decided to use a little hot glue instead. The actual STL can be downloaded from https://www.thingiverse.com/thing:5866505
19
laser alignment xr laser bracket
