a simple adjustable bracket I drew up to use in combination with, u channel or angle iron to create a fence for index cutting signs larger than the tables y axis. I used 14Ga but would recommend going with 12Ga instead for the fence I used some 2" aluminum U channel angle iron could be substituted uses bolts that are already in place no drilling required just install the brackets at water pan height and use 1/4-20 bolts to secure the fence to the brackets. simply bend bracket twice at 45 degrees approximately 3/8" in from the slots
125
crossfire pro
