One of the first brackets I designed as a learning project in Fusion360. The goal was to make a support for 2" tubing to support a bottom shelf. I didn't want to weld into the stock legs - this only requires 2 holes per leg. I used the sheet metal capabilities in F360 to make the flanges. This is also my first FileShare, so I thought I'd package it up to see how that works. Lots of ways to do this - this was what I came up with. If it helps you, hit like and leave a comment! Included tap (g-code) file with nesting for 4 parts ready to load and go. Make sure to remove the .txt extension! The tap file is based on a piece of 1/8" (.125 or 11ga) sheet 10" high x 7" wide to make all 4 parts. The bend radius calcs assume 1/8" material. You could make it with thinner or thicker material, but you'd need to adjust or not cut the bend lines to correct for the material thickness.
691
Crossfire Pro Bottom Shelf CAD Fusion 360
