I can't extrude the bigger pieces can someone here fix it?
Michael Gagne - 1 year ago
Hey, I opened it in fusion 360 and there is a line not touching to the other somewhere. It’s just under the bracket at the bottom left. Draw some lines from a line to another and you’ll see when the drawing becomes blue, you know that it’s not in this area. Start at the top going down. You will find it.
https://youtu.be/eIJBWq0Ti9E
Take a look at this video, he explains better than me. You will not always have a blank space between two lines like in the video. Draw two lines between the dot where you think it’s not touching, use the trim option to erase your lines and draw a single one to one point to the other. If the portion becomes blue you will be able to extrude.
Hope I could help you ;)
