12x2 inch key rack with 8 Tangs that can hold multiple key rings. I cut mine out of 14ga steel and then bent the tangs backwards at the mid pint about 45 degrees followed by bending at the base of the tang forward 45 degrees. It makes for a heavy duty key rack that does not stick out too far. There are mounting holes at either end.
600
