Very Simple Fire Pit. Steel is 12g You will need: 4 sides 1 base Plate 1 leg (file makes 4 legs) Assembly: Each side should be angled somewhere around 50degs. I tacked on the inside until I had all 4 sides on. Then welded up the entire outside seem. You can either chose to grind down the welds like I did or just leave them. The legs I desgined so they can be bent. I found this just made getting a square base a lot eaiser. I finished mine off with High heat paint from lowes (the 2000f stuff) im sure after awhile I will need to re paint Depending on where you get your metal it costs around $30ish dollars to make not including paint.
1445
Fire Pit welding fire
Cal Spigler - 3 years ago
